02-06-2013 01:56 AM - edited 03-16-2019 03:33 PM
Hi all,
At the moment i have a fax translation issue at our company.
Incoming line does not translate to the right number
What i would like to have is this=>
302837979 comes over the isdn line has to translate to => 2157979 to callmanager
Right nowe i have a couple of dial-peers created in my voicegateway finally it has to match to
the voip dialpeer 1058 (avaya qsig trunk)
In the callmanager it has then to remove the 21 ( then go to 57979)
But no translation is happening.
I will put my pots dial-peer hear and the voip dial-peer that has to match
Is there something i do wrong?
dial-peer voice 130 pots
description PSTN -> CUCM
translation-profile incoming faxdid
incoming called-number 302837979
no digit-strip
port 0/0/0:15
dial-peer voice 131 pots
no digit-strip
port 0/0/1:15
dial-peer voice 132 pots
no digit-strip
port 0/0/2:15
dial-peer voice 133 pots
no digit-strip
port 0/0/3:15
dial-peer voice 134 pots
no digit-strip
port 0/1/0:15
dial-peer voice 135 pots
no digit-strip
port 0/1/1:15
dial-peer voice 136 pots
no digit-strip
port 0/1/2:15
dial-peer voice 137 pots
no digit-strip
port 0/1/3:15
dial-peer voice 138 pots
no digit-strip
no digit-strip
port 0/0/0:15
no digit-strip
port 0/0/1:15
no digit-strip
port 0/0/2:15
no digit-strip
port 0/0/3:15
no digit-strip
port 0/1/0:15
no digit-strip
port 0/1/1:15
no digit-strip
port 0/1/2:15
no digit-strip
port 0/1/3:15
no digit-strip
no digit-strip
port 0/0/0:15
no digit-strip
port 0/0/1:15
no digit-strip
port 0/0/2:15
no digit-strip
port 0/0/3:15
no digit-strip
port 0/1/0:15
no digit-strip
port 0/1/1:15
no digit-strip
port 0/1/2:15
no digit-strip
port 0/1/3:15
no digit-strip
Translation to voip dial-peer 1058
dial-peer voice 1058 voip
description Avaya QSIG -> CUCM
translation-profile outgoing EXTERNAL->faxInation
preference 1
destination-pattern 215....
session protocol sipv2
session target ipv4:10.218.11.12
voice-class sip profiles 9
dtmf-relay h245-signal
codec g711alaw
fax rate 14400
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 2 fallback none
no vad
02-19-2013 02:37 AM
You don't need all these duplicate DPs. Have the configuration done by some professional.
