Fax - VG224 - MGCP
nellocon4
Hi Folks,
I have setup a VG224 via MGCP and it is registered to the call manager. When I dial the DDi number I have assigned to the port internally I can hear the Fax machine (analog dial up tone). However, when I try to dial the number externally, the fax machine rings once, and then answers but is just silent...
Any ideas why the fax will not work when coming in through the PRI line?
My config on the gateway is as follows and is the same on the VG224...
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback1
mgcp bind media source-interface Loopback1
acampbell
Shane,
From what you are showing here , you are running fax passthrough.
Your incoming gateway has to be configured to match this type of signalling.
If your gateway is H323 then you need to add a few lines of config.
Voice service voip
modem passthrough NSE codec g711ulaw
You can add this at dial peer level to be more granular:-
dial-peer voice 11 voip
description ### VOIP DIAL PEER TO CALL MANAGERS ####
preference 1
destination-pattern 6......
incoming called-number .
voice-class codec 1
voice-class h323 1
session target ipv4:10.182.182.12
dtmf-relay h245-alphanumeric
ip qos dscp ef media
ip qos dscp cs3 sig
no vad
Alex
Regards, Alex. Please rate useful posts.
Thanks for the reply!
I am running both the VG224 and the voice gateway on MGCP. So I beleive the incoming gateway is also running fax passthrough as the commands posted above are on both devices...
Is there a way I can check if I am running fax passthrough?
Shane,
So you reckon your incoming gateway is also MGCP.
Check for these statements under the MGCP sevtion.
mgcp modem passthrough voip codec g711ulaw
Alex
