Showing results forĀ
Search instead forĀ
Did you mean:Ā
Fax
Ronit Malhotra
We are facing Outbound fax issue while dialing specific number
RightFax >> SIP >> Gateway >> PRI
On Incoming dialpeer from sip
dial-peer voice 2 voip
session protocol sipv2
incoming called-number .
codec g711ulaw
fax-relay ecm disable
fax-relay sg3-to-g3
fax nsf 000000
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
no vad
Call connect for sometime than it get fail
Kunal Narula
Hi Dheeraj,
Can you please share 'show tech' along with output of 'debug ccsip messages','debug voice ccapi inout' and 'debug isdn q931' while testing fax on affected called number?
Kunal
