Error: CSeq: 101 CANCEL
cisco
Hi guys,
I'm with a problem, I can't call to specific number: +55 11 49505070 (From Brazil), but just of a specific locale (My enterprise). However, any other locale I can call to number.
I made several test with the telephone service provider, but they did tests and said that the "outside" is ok.
Below is the beginning of the log with the problem:
Oct 25 16:21:07.266: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:049505070@10.70.64.103:5060 SIP/2.0
Via: SIP/2.0/UDP 10.70.115.7:5060;branch=z9hG4bK182dcdc16620cbd
From: "Guilherme Saccomani" <sip:1149356018@10.70.115.7>;tag=468724820~7bbf4384-6963-497e-a741-183f9597fb99-64203507
To: <sip:049505070@10.70.64.103>
Date: Tue, 25 Oct 2016 16:20:56 GMT
Call-ID: 8d6980-80f18668-a026ee-773460a@10.70.115.7
CSeq: 101 CANCEL
Max-Forwards: 70
Content-Length: 0
Note: Only this phone has this problem: "CSeq: 101 CANCEL"
This type of problem has happened to you? Please, help me!
The complete log was attached.
Best Regards,
Tássio Duarte
A.Telecom
Kunal Narula
A. Telecom,
Cancel is a sip method seen when call signalling is abruptly ended before processing 200 ok method by a user agent.
Over here, can you please share below details so that problem can be diagnosed:
a)- What is the call flow?
b)- Is the phone registered on cucm or cme ?
c)- Has it ever worked in past? if yes, then is there any changes made in network?
d)- Share 'show tech' output from router.
e)- Share output of 'debug ccsip messages' along with 'debug voice ccapi inout'
Kunal
