Feature Difference between Cisco BE6K Version 8.6 and Normal CUCM 8.6
upchaurasia
  Hi All,
I am new to Cisco BE6K.
I would like to know if there is any difference in feature & functionality between Cisco BE6K version 8.6 CUCM and normal CUCM 8.6. As per my study feature wise both are same but there is restrictions on number of devices, users and trunks/gateways.
I hope, applications interfaces like AXL, JTAPI, CURRI, EM APIs are also supported in Cisco BE6K version 8.6 CUCM.
Thanks & Regards,
Umesh
Jaime Valencia
Pretty much is what you mention, the amount of devices is the difference between a standalone and a 6K install
Unified Communications Design and  Deployment Sizing Considerations
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/sizing.html#wp1146710
There's a link to the 6K wiki on that page if you want some further reading.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
The data sheet has pretty good summary:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps11369/data_sheet_c78-638921.html
All, applications are basically the same as standalone apps you would deploy.
Chris
