Feature hold hook hard phone 10 sec and auto dial
  We're stilling install CUCM v.12.5 and using phone type 7821 but not sure some phone feature function.
  caller hook hard phone over limit time (Ex 10 Sec) and phone auto dial to some DN internal number?
  please guide me about feature function or How we configure into CUCM.
Tom
As Java wrote it is not all clear what your question is, but if your asking for PLAR with a 10 second delay before the number is dialled I don’t think that this is possible. Configuring a PLAR, aka call something automatically as soon as the phone goes off hook, is absolutely possible and there are good reference documentation for this. It’s the part of the 10 second delay between off hook and making the call that AFAIK cannot be done.
Response Signature
5 Replies 5
Jaime Valencia
If you mean you want to configure a PLAR, there's plenty of documentation available on the configuration you can review if you spend a few minutes searching CSC or google.
If that's not what you're looking for, might want to rephrase what you're asking as it's not completely clear what you mean by "hold hook hard phone"
java
if this helps, please rate
Hi Jaime
  Thank you for answer PLAR, But don't sure can we set a delay time off hook around 10 sec before phone auto dial?
Tom
Response Signature
Dear Roger
  Thank you so much for answer my question.
Tom
PTS
HI
If you are open to 3rd party solutions then your requirement can be achieved via custom Cisco JTAPI based application.
For more info please write to info@parsec-tech.com
