10-24-2012 08:18 AM - edited 03-16-2019 01:51 PM
Yesterday our phones failed over from primary to secordary then back to primary server. Now, features like Call Forward and voicemail indicator are not working from the phones. Does anyone have any suggestions as to how to fix this? Is it a database issue?
10-24-2012 08:28 AM
What version are you on?
Sounds like DB replication might have an issue, take a look at this doc to check if db replication is OK:
https://supportforums.cisco.com/docs/DOC-13672
HTH,
Chris
10-24-2012 08:32 AM
we are using version 8.6 thanks
10-24-2012 08:42 AM
the DB status report came back as 2 - replication is good
10-24-2012 10:54 AM
What call FW are you talking about?? and what do you see/hear when you try to enable/change it?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-24-2012 10:55 AM
actually, at first I thought it was just a CFA and MWI issue. However, any changes made on the publisher are not being pushed to the phones. We have a TAC case opened but no leads yet
10-24-2012 11:36 PM
If changes are not pushing through, then it is a replication issue. I'd recommend re-initializing replication.
10-25-2012 11:51 AM
it turned out to be a database replication error. However, after syncing the database the servers needed to be restarted to fix the problem
10-25-2012 12:08 PM
Great, these types of issues as indicated in initial reply are usually common to DB replication issues.
Please rate all useful posts!
Chris
