07-04-2022 01:29 AM
Hi All
Question: Is there any way to find the MAC address of a PC which connected to Cisco ip phone directly from IP phone?(its web or ssh)
my ip phone model here: CP-7821
Note: I know that we can find it from Cisco switch using command “ show MAC address-table int …”
best regards
Sina HR.
07-04-2022 01:46 AM
Try it.
If there is a PC connected to the phone's pass-through port, the switch output will show two MAC addresses.
07-04-2022 01:53 AM
Hi Leo
i have mentioned that in my Note. I need it from ip phone directly.
thanks.
07-04-2022 03:24 AM
From a 7800/8800/9900, no.
I believe this feature is only available in 7900 phones.
07-04-2022 02:09 AM
yes you can do if you know the where interface connected : as example :
#show mac address-table interface tw 1/0/18
Mac Address Table
Vlan Mac Address Type Ports
9XX XXXX.XXX STATIC Tw1/0/18
9XX YYYYYYYYYYY STATIC Tw1/0/18
Total Mac Addresses for this criterion: 2
07-04-2022 03:26 AM
Hi dear
I told that I wanna find from ip phone directly and not switch. I know that we can ssh to Cisco ip phone. So Is there any command in ip phone ssh? Or from cisco ip home web page.
thanks
07-04-2022 03:29 AM
simple answer NO as per i know.
