Find PC’s MAC address connected to Cisco ip phone
s.maxina1
Hi All
Question: Is there any way to find the MAC address of a PC which connected to Cisco ip phone directly from IP phone?(its web or ssh)
my ip phone model here: CP-7821
Note: I know that we can find it from Cisco switch using command “ show MAC address-table int …”
best regards
Sina HR.
6 Replies 6
Leo Laohoo
Try it.
If there is a PC connected to the phone's pass-through port, the switch output will show two MAC addresses.
Hi Leo
i have mentioned that in my Note. I need it from ip phone directly.
thanks.
From a 7800/8800/9900, no.
I believe this feature is only available in 7900 phones.
balaji.bandi
yes you can do if you know the where interface connected : as example :
#show mac address-table interface tw 1/0/18
Mac Address Table
Vlan Mac Address Type Ports
9XX XXXX.XXX STATIC Tw1/0/18
9XX YYYYYYYYYYY STATIC Tw1/0/18
Total Mac Addresses for this criterion: 2
BB
Hi dear
I told that I wanna find from ip phone directly and not switch. I know that we can ssh to Cisco ip phone.  So Is there any command in ip phone ssh? Or from cisco ip home web page.
thanks
simple answer NO as per i know.
BB
