10-20-2016 10:12 AM - edited 03-17-2019 08:25 AM
Good day!!
One question, I try to change the firmware to Cisco 8831 for this "cp-8831-sip.9-3-4-SR2-3PCC.bin.sgn" for connecto to other vendor PBX.
But way CUCM OS Administration --> Software Upgrades --> Install/Upgrade not is possible the firmware don´t appear in the list.
I try with url page http://<dirección_IP_del_teléfono>/upgrade?tftp://<dirección_IP_del_servidor_TFTP>/<archivo_binario_del_firmware>
http://10.118.49.41/admin/upgrade?tftp://10.127.3.73/cp-8831-sip.9-3-4-SR2-3PCC.bin.sgn
10.118.49.41 IP Address CP 8831
10.127.3.73 IP my host TFTP Server.
Firmware: cp-8831-sip.9-3-4-SR2-3PCC.bin.sgn
But show the next error:
Actually the CP 8831 have the firmware:
Active Load ID: | sip8831.10-3-1-1 |
How I changed the firware for CP8831 ??
10-22-2016 11:59 PM
Check you tftp path i believe it is not pouting correctly. Just upload any other Firmware image and see if that pop up via tftp.
Please rate and mark correct answers<<
10-24-2016 07:27 AM
Hi Christian,
My understanding here is that once an 8831 has been configured with Cisco "enterprise" (standard) firmware it can no longer be converted to use 3pcc firmware;
You can upgrade phones from the third-party call control firmware to the enterprise firmware.
![]() Caution |
After you upgrade to the enterprise firmware, you cannot revert to the third-party call control firmware. |
From;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8831/3PCC/firmware/9-3-4-sr2/cs38_b_phone-8831-3pcc-release-934sr2.html#task_98936B6D56E12D7431B7FF70EB1C0303
Cheers!
Rob
10-24-2016 07:40 AM
In this moment the CP8831 it is registered with the CUCM,
Then it is not possible? I need a new endpoint for this?
10-24-2016 07:47 AM
Hi Christian,
Sadly yes, that is my understanding here my friend.
Cheers!
Rob
04-26-2018 11:42 AM - edited 04-26-2018 11:47 AM
from what I'm seeing, we cannot upgrade Enterprise firmware to third Party Call Control firmware. but reading the link, I don't see the caution or warning on the page? are they allowing it now? :D
just wondering
Caution
From;
10-26-2016 09:07 AM
Would a hard/factory reset solve this issue?
you might try reading the following discussion:
https://supportforums.cisco.com/discussion/12429241/8831-factory-reset
09-05-2017 12:14 AM
A hard/factory reset will not solve the issue. Once the phone is locked to an Enterprise firmware it is there to stay.
03-30-2018 12:06 AM
Following an update of my Cisco CP-8861 3PCC to a firmware version 11.0.1 MPP, I have the screen with a white background.
I want to go back to a previous firmware previous to version 11.0.0, I'm looking for the firmware sip88xx.10-3-1-9-3PCC for CP-88XX 3PCC containing the following files:
fbi88xx.10-3-1-9-3PCC.sbn
kern88xx.10-3-1-9-3PCC.sbn
rootfs88xx.10-3-1-9-3PCC.sbn
sb288xx.10-3-1-9-3PCC.sbn
sip88xx.10-3-1-9-3PCC.loads
vc488xx.10-3-1-9-3PCC.sbn
I'm calling for your help can anyone among you have the sip88xx.10-3-1-9-3PCC firmware I need?
Thanks for your help !
