FL-CME-SRST-25 for 2921 UC-CME
timothy 2617
Folks,
Is it still possible to purchase a FL-CME-SRST-25 license?  I'd like to set up a very basic two-handset network at home.  There are plenty of 2921 G2's with the UC/K9 feature enabled but not so many with an FL-CME-SRST-XX license.  The choice of the 2921 was the reasonably low cost of being able to tinker.
Thank you for your time.
Timothy
The CME/SRST licenses are RTU, so there is no actual hard check that you have it on the router. If you’re not to conclusions about being audited you could go about yours with this.
Response Signature
Response Signature
FL-CME-SRST-25 Got EOL.
Those router  you mentioned can run cme without license as they are RTU license.
With new smart licensing model no more  RTU.
Response Signature
