ā05-04-2023 02:11 PM - last edited on ā05-04-2023 11:14 PM by rupeshah
I have two callmanager the firts callmanager is callmanager express 4.0 and the other is a callmanager 4.1 the forwanding between numbers internals is working. The extension number for callmanager 4.1 is 2.. and the extension number for callmanager express 4.0 is 4..
My problem is when wanna forwanding a external number from callmanager 4.1 toward callmanager 4.0 express the call arrive but when answer the call finish.
i search a solution but i canĀ“t found.
your , help is much appreciated
copy and paste the config callmanager express 4.0 thanks:
Current configuration : 16570 bytes
version 12.4
service sequence-numbers
hostname xxx
boot-start-marker
boot system flash c2800nm-ipvoicek9-mz.124-11.XW6.bin
boot-end-marker
logging buffered 4096
enable secret xxx
enable password xxx
no aaa new-model
clock timezone SCL -4
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.3.17.1 10.3.17.225
ip dhcp excluded-address 10.3.17.250 10.3.17.255
ip dhcp pool Telefonia_IP
network 10.3.17.0 255.255.255.0
default-router 10.3.17.1
option 150 ip 10.3.17.4
ip dhcp pool prueba
network 192.168.4.0 255.255.255.0
default-router 192.168.4.1
option 150 ip 192.168.4.7
no ip domain lookup
ip host sw 10.3.17.5
ip name-server 10.3.3.36
ip dhcp-server 10.3.17.4
trunk group PBX
max-calls voice 4
max-retry 3
hunt-scheme round-robin
password encryption aes
voice call send-alert
voice rtp send-recv
voice service voip
supplementary-service h450.12
h323
no call service stop
call start slow
modem passthrough nse codec g711alaw
sip
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711alaw
codec preference 3 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
voice register global
mode cme
max-dn 144
max-pool 42
voice-card 0
dspfarm
file verify auto
username xxx password xxx
archive
log config
hidekeys
interface FastEthernet0/0
ip address 10.3.17.4 255.255.255.0
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.3.17.4
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.4.1 255.255.255.0
interface FastEthernet0/1.3
encapsulation dot1Q 3
ip address 192.168.1.5 255.255.255.252
ip route 0.0.0.0 0.0.0.0 10.3.17.1
ip http server
no ip http secure-server
ip http path flash:gui
tftp-server flash:SCCP11.8-2-2SR2S.loads alias SCCP11.8-2-2SR2S.loads
tftp-server flash:term06.default.loads alias term06.default.loads
tftp-server flash:term11.default.loads alias term11.default.loads
tftp-server flash:cvm11sccp.8-2-2TR2.sbn alias cvm11sccp.8-2-2TR2.sbn
tftp-server flash:jar11sccp.8-2-2TR2.sbn alias jar11sccp.8-2-2TR2.sbn
tftp-server flash:dsp11.8-2-2TR2.sbn alias dsp11.8-2-2TR2.sbn
tftp-server flash:apps11.8-2-2TR2.sbn alias apps11.8-2-2TR2.sbn
tftp-server flash:cnu11.8-2-2TR2.sbn alias cnu11.8-2-2TR2.sbn
tftp-server flash:P00308000500.bin alias P00308000500.bin
tftp-server flash:P00308000500.sbn alias P00308000500.sbn
tftp-server flash:P00308000500.sb2 alias P00308000500.sb2
tftp-server flash:P00308000500.loads alias P00308000500.loads
tftp-server flash:S00105000200.sbn alias S00105000200.sbn
tftp-server flash:SCCP41.8-2-2SR2S.loads alias SCCP41.8-2-2SR2S.loads
tftp-server flash:term41.default.loads alias term41.default.loads
tftp-server flash:term61.default.loads alias term61.default.loads
tftp-server flash:apps41.8-2-2TR2.sbn alias apps41.8-2-2TR2.sbn
tftp-server flash:cnu41.8-2-2TR2.sbn alias cnu41.8-2-2TR2.sbn
tftp-server flash:cvm41sccp.8-2-2TR2.sbn alias cvm41sccp.8-2-2TR2.sbn
tftp-server flash:dsp41.8-2-2TR2.sbn alias dsp41.8-2-2TR2.sbn
tftp-server flash:jar41sccp.8-2-2TR2.sbn alias jar41sccp.8-2-2TR2.sbn
tftp-server flash:SCCP11.8-4-3S.loads alias flash:SCCP11.8-4-3S.loads
tftp-server flash:P00308000400.sbn alias P00308000400.sbn
tftp-server flash:P00308000400.bin alias P00308000400.bin
tftp-server flash:P00308000400.sb2 alias P00308000400.sb2
tftp-server flash:P00308000400.loads alias P00308000400.loads
tftp-server flash:P00308000200.bin alias P00308000200.bin
tftp-server flash:P00308000200.sbn alias P00308000200.sbn
tftp-server flash:P00308000200.sb2 alias P00308000200.sb2
tftp-server flash:P00308000200.loads alias P00308000200.loads
control-plane
voice-port 0/0/0
trunk-group PBX
no battery-reversal
timeouts call-disconnect 5
connection plar opx 495
description 075-385117
station-id number
caller-id enable
voice-port 0/0/1
trunk-group PBX
supervisory disconnect anytone
no battery-reversal
timeouts call-disconnect 2
timeouts wait-release 2
timing hookflash-out 500
timing digit 500
station-id number
caller-id enable
voice-port 0/0/2
trunk-group PBX
no battery-reversal
timing digit 500
connection plar 480
description 075-75383339
station-id number
caller-id enable
voice-port 0/0/3
trunk-group PBX
no battery-reversal
timing digit 500
connection plar 480
description 075-75384958
station-id number
caller-id enable
voice-port 0/1/0
trunk-group PBX
no battery-reversal
timing digit 500
connection plar 480
station-id number
caller-id enable
voice-port 0/1/1
no battery-reversal
connection plar 480
shutdown
no mgcp timer receive-rtcp
dial-peer cor custom
name local
name celular
name interno
name LD
dial-peer cor list call-local
member local
member interno
dial-peer cor list call-interno
member interno
dial-peer cor list user-interno
member local
member interno
dial-peer cor list call-celular
member celular
dial-peer voice 1 voip
preference 1
destination-pattern 2..
voice-class codec 1
voice-class h323 1
session target ipv4:10.3.20.2
dtmf-relay h245-signal h245-alphanumeric
no vad
dial-peer voice 2 voip
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.3.20.3
no vad
dial-peer voice 20 pots
trunkgroup PBX
corlist outgoing call-celular
description Llamadas Celulares
destination-pattern 90[5-9]........
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
forward-digits 8
prefix 9
dial-peer voice 10 pots
trunkgroup PBX
corlist outgoing call-local
description Llamadas PSTN
destination-pattern 9.T
dial-peer voice 3 voip
preference 2
destination-pattern 4..
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 300 voip
description Anexos Internos PBX
destination-pattern 3..
session target ipv4:10.3.20.4
codec g711alaw
dial-peer voice 270 voip
destination-pattern 2[67][45]
codec g711alaw
dial-peer voice 11 pots
dial-peer voice 4 voip
destination-pattern 802.........
voice-class codec 1
voice-class h323 1
presence
gateway
timer receive-rtp 1200
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 50
load 7960-7940 P00308000200
load 7914 S00105000200
load ATA ATA030203SCCP051201A.zup
load 7941 SCCP41.8-2-2SR2S
load 7961 SCCP41.8-2-2SR2S
load 7911 SCCP11.8-2-2SR2S
load 7912 CP7912080002SCCP060817A
max-ephones 40
max-dn 40
ip source-address 10.3.17.4 port 2000
timeouts interdigit 2
system message Frutec Curico
user-locale ES
time-zone 15
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern .T
moh flash:music-on-hold.au
multicast moh 239.100.9.1 port 2000
web admin system name xxx password xxx
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp 7960 Dec 07 2022 09:52:11
ephone-template 1
ephone-dn 1
number 412
label Oficina Produccion
description Oficina Produccion
name Oficina Produccion (Curico)
ephone-dn 2
number 417
label Control de procesos
description Control de procesos
name Control de procesos
hold-alert 30 originator
ephone-dn 3
number 480
label Recepcion Curico
description Recepcion
name recepcion
call-forward busy 481
ephone-dn 4
number 400
label
description
name
corlist incoming call-local
ephone-dn 5
number 402
label
description
name
ephone-dn 6
number 403
label
description
name
ephone-dn 7
number 490
label
description
name
ephone-dn 8
number 410
label
description
name
corlist incoming call-interno
ephone-dn 9
number 411
label
description
name
ephone-dn 10
number 413
label
description
name
ephone-dn 11
number 415
label
description
name
ephone-dn 12
number 416
label
description
name
ephone-dn 13
number 417
label
name Control de Procesos
ephone-dn 14
number 418
label
description
name
ephone-dn 15
number 419
label
description
name
ephone-dn 16
number 401
label
description
name
ephone-dn 17 dual-line
number 481
label
description
name
call-forward busy 482
ephone-dn 19
number 423
label
description
name
ephone-dn 20
number 420
label
description
name
ephone-dn 21
number 406
label
description
name
ephone-dn 22
number 482
label
description
name
ephone-dn 23
number 407
label
description
name
ephone-dn 25
number 425
label Fax
description Fax
name Fax
ephone-dn 26
number 426
label Fax 2
description Fax2
name Fax2
ephone-dn 27
number 421
label
description
name
ephone-dn 28
number 422
label
description
name
ephone-dn 29
number 405
label
description
name
ephone-dn 30
number 404
label Certificacion Curico
description Certificacion Curico
name Certificacion Curico
ephone-dn 31
number 414
label
description
name
ephone-dn 33
number 470
label
description
name
ephone-dn 34
number 488
label
description
name
ephone-dn 35
number 489
label
description
name
ephone 1
description
mac-address 001D.4595.9C2B
username "xxx" password xxx
type 7911
button 1:14
ephone 2
description
mac-address 0007.0E6C.EC43
type 7911
button 1:2
ephone 3
description
mac-address 0019.AAA6.3643
type 7960 addon 1 7914
button 1:3 4:22 7s4 8s16
button 9s5 10s20 13s21 14s7
button 15s9 16s1 17s10 20s14
ephone 4
description
mac-address 001D.4561.89C2
type 7912
button 1:4
ephone 5
description
mac-address 0017.95F8.B8EF
type 7912
button 1:5
ephone 6
description
mac-address 001B.5348.9A82
type 7912
button 1:1
ephone 7
description
mac-address 0016.C72D.3585
type 7912
button 1:7
ephone 8
description
mac-address 001D.4595.A2AF
username "xxxx" password xxx
type 7911
button 1:8
ephone 9
description
mac-address DC7B.94F8.8B08
type 7940
button 1:9
ephone 10
description
mac-address 001D.7060.0197
type 7912
button 1:6
ephone 11
description
mac-address 001B.5336.2410
type 7912
button 1:10
ephone 12
description InspSag
mac-address 0019.E85D.7976
type 7912
button 1:12
ephone 13
description control
mac-address 0024.C444.494C
username "xxx" password xxxx
type 7911
button 1:13
ephone 14
description CCARecepcion
mac-address 0024.C443.E2C9
button 1:14
ephone 15
description
mac-address 001D.4543.6A66
type 7911
button 1:15
ephone 16
description
mac-address DC7B.94F8.8E08
button 1:16
ephone 17
description
mac-address 0016.4760.35AE
type 7940
button 1:20
ephone 18
description
mac-address 0023.5E18.C305
type 7911
button 1:23
ephone 19
description
mac-address 0023.049C.BFBE
keyphone
type 7911
button 1:19
ephone 20
description
type 7941
ephone 21
description
mac-address 0016.C71C.00FA
type 7912
button 1:21
ephone 22
mac-address 1BD4.C70A.7D01
type ata
button 1:26
ephone 23
description
mac-address 1956.4A1B.1101
type ata
button 1:28
ephone 24
mac-address 1234.5C54.6432
ephone 25
description
mac-address 001B.D4C7.0A7D
type ata
button 1:25
ephone 26
ephone 27
description
mac-address 0019.564A.1B11
type ata
button 1:27
ephone 29
description
mac-address 0023.049C.E895
type 7911
button 1:29
ephone 30
description
mac-address 0016.C72D.3A02
type 7912
button 1:30
ephone 31
mac-address 001D.4595.A21A
type 7911
button 1:31
ephone 32
description Prueba ip comunicator
ephone 33
description
mac-address 003C.5948.5C01
type CIPC
button 1:33
ephone 34
description
mac-address 38F3.AB3B.8C50
type CIPC
button 1:34
ephone 35
description
mac-address 0023.3319.3FD6
type 7911
button 1:35
scheduler allocate 20000 1000
ntp clock-period 17180235
ntp server 200.1.19.4
end
Solved! Go to Solution.
ā08-25-2023 10:06 AM
The solution for me was to leave in my cucm 4.1 the ip of the gw call manager express 4.0 and configure the same device pool (default is my case).
