Forward call according to a timetable
racimkhiari
Could I organize call forward (for a separate phone number) according to a timetable - for ex. each day from 6 p.m. to 7 a.m. forward all calls from 0770910971 to mobile phone, on CUCM 7.1(5).
Thanks in advance
I think the best solution for this is to configure mobile connect for callmanager. This way when somebody calls an ip phone callmanager also rings the mobile phone associated with it.
You can also configure when this feature should be enabled (date, time)
In the admin pages ----> Device ---> Remote destination
For any additional info you can see the relevant section in the features and services guide of callmanager os simply post here
Hope it helps,
Christos
I think you can. Use "Time of the day routing" feature.
Here is config for 6cucm .x but it similar in cucm 7.x
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080a7bc96.shtml
Create different TP with called party transform mask set as desired forward number (each in partition with time schedule) but with the same pattern (lets say 12345)
Then forward call from phone to 12345. So depending on time of the day call forward will hunt different TP which in it turn will forward call to the number you've specified as called party transorm mask.
