forward call to cisco unity after 1 ring
mrmarie
I have an issue with one phone extension only registered to 3 Cisco Phones (DX80, 8861, 8841). when i call it ring for 1 time then forward the call to Cisco unity, so how can i disable the forwarding call.
Appreciate your help
Mike_Brezicky
Check the Call Forwarding Settings on the Directory Number.
If the Cluster / Enterprise Setting has not changed, look at the No Answer Ring Duration (seconds) setting and try to update it to a new, longer value.
Hello Mike,
Here is the call forward setting
I already change the ring duration to 15 Seconds bas still have the same issue.
Mr Marie,
According to that screen shot, you don't have it forwarding to vm or any other destination. None of the boxes are checked and there is no destination listed next to it. Are they getting to the correct vm or are the getting the Cisco Unity attendant?
