09-05-2013 04:12 PM - edited 03-16-2019 07:14 PM
Is it possible to enable call forwarding from your voicemail menu?
Scenario: Call voicemail > enter ext./password > menu "5" forward calls > enter number to forward calls to.
Thanks.
09-05-2013 04:47 PM
If you mean to change the call forward settings from CUCM via Unity/CUC, no, that's not possible.
HTH java if this helps, please rate www.cisco.com/go/pdihelpdesk
Log in to Community
