forward inbound GSM call from gsm gateway to Cisco CUCM
georgeotj
I've created SIP Trunk between Yeastar TG-100 GSM Gateway and Cisco CUCM.
TG-100 ip address is = 172.68.9.41
Cisco CUCM ip address is = 172.68.9.31 (extension number is 10xxx)
In TG-800, i create two call route, one for Cisco to GSM and other for GSM to Cisco.
VoIP Phones behind CUCM (10xxx) can make calls to GSM numbers (+62821xxxxxxx) through TG-100 successfully.
But when doing call outside office to GSM number at TG-100, i could get the Cisco CUCM tone but when dial the extension number, nothing happens, until call terminated.
Could anyone give me a hint what to check at Cisco CUCM to might be the culprit to this problem ?
Thanks.
I finally solved it.
So, after i put the CSS as recommended by Nashaatmusa, i also create Route List, Route Group for this SIP Trunk and edit the Trunk Security Profile as attachment.
I do reset at the Trunk, SIP Trunk Security Profile, and suddenly it all works.
Thank you Nashaatmusa.
7 Replies 7
Nashaatmusa
are your phones assigned partitions ?? ,, as the Trunk has no CSS !!
yes, i assigned partition to the voip phones.
do you mean that i had to config CSS (Calling Search Space) at the Cisco CUCM Trunk ?
(as attachment)
Exactly, as the SIP trunk can't reach the phones with CSS assigned to it.
put CSS in place as picture , apply config , reset sip trunk if needed and give it a go
Ok, so i put the CSS in place, apply config. But still same result, i got Cisco CUCM tone but no other response until call ended.
I attached the Cisco CUCM trunk config i modified, and also below is the log from TG-100, maybe there are something in there, tbh i don't really understand the information on the log
Via: SIP/2.0/UDP 172.68.9.41:5060;branch=z9hG4bK5e464dcd;rport
Max-Forwards: 70
From: "Unknown" <sip:Unknown@172.68.9.41>;tag=as7c358506
To: <sip:172.68.9.31>
Contact: <sip:Unknown@172.68.9.41>
Call-ID: 40e2099c0790557200d3fc187bd32320@172.68.9.41
CSeq: 102 OPTIONS
User-Agent: TG100
Date: Thu, 05 Jul 2018 16:22:07 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces, timer
Content-Length: 0
<--- SIP read from UDP:172.68.9.31:5060 --->
SIP/2.0 200 OK
To: <sip:172.68.9.31>;tag=1813280668
Server: Cisco-CUCM12.0
CSeq: 102 OPTIONS
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Content-Length: 0
Good to know ! , best of luck
hello
i have the same probelm
why did you create route list and route group ??
the probelm for you was only on css si trunk ??
best regards
