Forward no answer external not working
m.soleimani
We have a Cisco Model ISR4451-X/K9 router with Cisco IOS XE Software Version 16.03.05 as H.323 voice Gateway and Cisco Call manager version: 11.5.1.22900-28. Voice gateway connected to PSTN with 4 PRI (E1/T1) ports.
I set “Mobile Number A” for Directory Number(DN) Forward No Answer External but When outbound call established to DN After No Answer Ring Duration the call drops but “Mobile Number A” still ringing!!!
Forward All works Fine with same scenario.
card type e1 0 1
card type e1 0 2
isdn switch-type primary-net5
trunk group 1
max-calls voice 120
hunt-scheme random
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
callmonitor
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
voice class codec 2
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class h323 1
h225 timeout tcp establish 3
voice class dualtone-detect-params 77
freq-max-deviation 30
voice class custom-cptone morocco
dualtone disconnect
frequency 435
cadence 500 500
voice-card 0/1
no watchdog
controller E1 0/1/0
framing no-crc4
pri-group timeslots 1-31
interface Service-Engine0/1/0
description E1-module-1
interface Serial0/1/0:15
description To-Carin-switch
no ip address
encapsulation hdlc
isdn overlap-receiving T302 20000
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
trunk-group 1
no cdp enable
voice-port 0/1/0:15
translation-profile incoming PSTN-I
echo-cancel mode 2
no non-linear
no vad
timeouts call-disconnect 3
timeouts wait-release 3
bearer-cap Speech
gateway
timer receive-rtp 1200
sip-ua
retry invite 3
retry response 3
retry bye 3
retry cancel 3
timers trying 1000
network-clock synchronization automatic
network-clock input-source 1 controller E1 0/1/0
ntp server vrf Mgmt-intf  prefer
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
7 Replies 7
Can you please make a call to that extension from external while activating these 3  debug commands and post the output?
debug isdn q931
debug voip dialpeer inout
debug h225 q931
Thanks a lot
Carlo
Please rate all helpful posts "The more you help the more you learn"
m.soleimani
Hi Carlo,
Sorry for delay in response, the attachment is logs for debug commands you Told me.
m.soleimani
Thanks for logs.
It seems that you send the a wrong calling number to the PSTN.
Can you please call the mobile number from the same extension and post the same logs
Also... When you call the internal DN from an external user, what is the exect behaviour?
Thanks a lot
Carlo
thanks for your quick response
I send the a originator calling number from h.323 gateway to the PSTN.
I figured out external source treated as internal call and CUCM used "Forward No Answer Internal" for external call, but this scenario it works fine for "Forward All". I gather the logs you requested tonight and tomorrow I will send to you.
m.soleimani
I set call classification = "use system default" for h.323 gateway config
and set call classification= "Offnet" for route pattern definition
Service Parameters
Regards.
So, speifying off-net as off-net call , solved your issue?
Thanks a lot
Carlo
m.soleimani
Maybe but I don't know how...
