How to forward DID number from FXO to Asterisk?
Matthew Nasr
Hi everyone.
I have a cisco 2811 with FXO modules that is connected to an Asterisk IPPBX server. Every thing is working fine. But there is a problem with DID. I'm using connection-plar 2000 for forward incoming calls to asterisk. Therefore I can not find that the caller person called which number to income to my asterisk, because I see just 2000 as DID from asterisk perspective.
Is there any way to forward DID called by callers to asterisk without changing?
Best regards
Matthew Nasr
Dear @Leonardo Santana
Do you have any idea?
Being Asterisk I assume that you are using SIP dial peer to route calls to him.
Make sure to have caller-id enable command on your FXO voice port and remote-party-id under sip-ua section
Please let us know
BR
Carlo
Please rate all helpful posts "The more you help the more you learn"
ahmed.zakaria
Dear Nasr,
             please share configuration for dial-peer and voice-port you create on cisco router and configuration on
Asterisk server
