01-26-2019 07:05 AM - edited 03-17-2019 02:00 PM
Good day Experts..
I seem to be running in to some complex configurations day in day out huh... Anyways I have a SIP trunk from MyPBX to CUCM that is working perfect thanks for the team here for bringing it up adn working.
Issue is CUCM has SIP trunks to other branches how do i make this CUCM forward calls that come from Extentions that are on MyPBX destined to the branches?
(1002)<======>MyPBX<======SIP Trunk 1=====>CUCM<======SIP Trunk 2==========> Branches<==>(3001)
Looking at the Above i want to achieve the above where my extension 1002 calling a branch extension 3001 where the branch has a SIP trunk with CUCM but branch has no SIP trunk with MyPBX. Note that i can call all extensions that are connected to CUCM.
If this cant work whats the best solution i can have just have SIP trunks to the branches??? and have a seperate outgoung route list for the branches?
Thanks in advance.
01-26-2019 08:05 AM
Simply configure your call routing to do that, adjust the inbound CSS from one trunk to use the RP to the other trunk and make sure it's the best match.
01-26-2019 08:43 AM
Jammie, thanks for the quick response much appreciated. I was of the same Idea but i cant find some working configuration that i can use to learn from or see how it works. Will appreciate that input.
01-26-2019 09:33 AM
CSS and partitions, that's it.
Think of each trunk as any other phone, adjust the CSS so it can reach the desired route pattern. Do any digit manipulation you might need based on your configuration.
