Forwarding calls to voicemail
martinm01
Is it possible to forward calls that I take (as an admin assistant) DIRECTLY in to my boss' voicemail??   New to this phone system, so it may be simple but I can't figure it out!  Thanks!
John Huthmaker
Level 4
Level 4
The short answer is "It depends".  Speak to the person in charge of your phones.  On the last system I administered, I added an option to add an asterisk in front of an extension, and that would put you right in to a persons voicemail.  If that was the case, you could forward the call to asterisk and your bosses extension, and that would do it.  But that only works if its set up.
This discussion has been reposted from Additional Communities to the IP Telephony community.
Dan Lukes
Wrong community to ask this and you didn't specified what you mean saying "this phone system", so don't wish so much for valuable reply here.
Wilson Samuel
Level 7
Level 7
Hi There,
Presume you are using CUCM, yes, it is possible to forward calls to directly forward to someone's voicemail.
The idea is that you have Voicemail Profile with a special character like * or # (only these two are dialable from the phones).
When someone needs to be transferred to their voicemail , simply hit Transfer and # or * and dial the number and it will transfer the call to the Unity Connection, effectively delivering the call to the recipient's voicemailbox.
