CUCM & NTP Authentication
Hi everyone
Our network guys recently setup some new NTP servers that require authentication. I know you can configured the following on a router/switch to allow for this, but is there a way to configure this for CUCM? I'm running 8.6
ntp authentication-key 5 md5 **********
ntp authenticate
ntp trusted-key 5
ntp update-calendar
ntp server 1.1.1.1 key 5
2 Accepted Solutions
Jaime Valencia
No, CUCM needs an NTP that has no authentication. All you get to configure regarding NTP, is the IP.
java
if this helps, please rate
Nadav
Level 7
Level 7
Just adding to Jaime's response:  The fact that your NTP server has an authentication key in no way stops you from syncing CUCM with it, you will simply be synching to it unauthenticated. The authentication key is there to authenticate the ntp server, and not the clients.
There is only an issue if the client supplies an authentication string for a key to sync with the server, but the server doesn't have the same key with the same authentication string. See the following article for details:
http://www.ine.com/resources/ntp-authentication.htm
Jaime Valencia
java
[+5] to both of you for sharing good info.
I have been try to rate both but is not working.
wud try later.
regds,
aman
working now.
regds,
aman
Nadav
Level 7
Level 7
