IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6100 Views
  • 14 replies
Hi, all.IP Phone 7961 was used for a long time, but I'm advancing a replace to 7962.When it's being called in 7961, I feel noise because it was used by a network with a lot of jitters. But after exchanging it for 7962, I don't feel noise. Jitter meas...
amigo by Level 1
  • 536 Views
  • 2 replies
Disclaimer: I just joined this company so I'm still learning the lay of the land, and I'm a Network Admin, not a voice guy. We have an install guy, but he quite literally installs the phones and creates a voicemail profile for users. He doesn't have ...
Hello - we have been seeing this error sporadically on our SIP PSTN GW's. %FLEXDSPRM-3-UNSUPPORTED_CODEC: codec cisco is not supporte d on dsp 0/3 Jul 22 11:03:35.405: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally What could...
Ed Kender by Level 1
  • 386 Views
  • 3 replies
Hello Experts,I know that configuring a phone with different values should over write the default ones set in the Service Parameter. But no matter what value I put in the phone configuration, the ones set in the Service Parameter take place. Here`re ...
I'm trying to setup some shared lines and hunt groups but I'm not sure it's achievable. We have 7962 phonesMy requirements are:Externally: one number to call one hunt group internally via broadcast 3000,3001,3002,3003 (these numbers have external DDI...
louis0001 by Level 3
  • 2079 Views
  • 6 replies
We have a number of routers at our branch locations configured as H.323 gateways.  We run a CUCM 9.1.2 cluster at our main office w/ associated CUC and CCX boxes.  Each branch router is also configured for SRST.  Recently we decided to change the hos...
moore_j58 by Level 1
  • 416 Views
  • 3 replies
