Foward call FXS port on CME
quytx2
HI every one
I have CME ISR 4331.i want to forward call to PSTN when analog phone not pick up call when call arrives . can you help me thiss issue.
Site A (CME01) ------SIP------Site B(CME02)(have 1 FXS and 1 FXO)
8 Replies 8
BalajiSivaraj49175
This configuration is for SIP trucking dial-peer configuration
dial-peer voice 1 voip
description **Incoming Call from SIP Trunk**
translation-profile incoming CUE_Voicemail/AutoAttendant
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
incoming called-number .%
dtmf-relay rtp-nte
no vad
dial-peer voice 2 voip
description **Outgoing Call to SIP Trunk**
translation-profile outgoing PSTN_Outgoing
destination-pattern 9........
voice-class codec 1
dtmf-relay rtp-nte
no vad
BalajiSivaraj49175
Used by CME to send its IP address to SP proxy instead of CUE
session target ipv4:172.22.1.155
dtmf-relay sip-notify
BalajiSivaraj49175
Ephone configuration for dual line
ephone-dn 12 dual-line
number 202 secondary 5123781202 no-reg both
name
call-forward busy 600
call-forward noan 600 timeout 15
BalajiSivaraj49175
This link will helpful resolve this issue This have every services CUE CME that configured Dialpeer phone DN and other services
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/91535-cme-sip-trunking-config.pdf
Which call u need to forward ? calls from SITE A to site B if not answered will get forwarded to PSTN using FXO or if  someone call Site B from PSTN and if not answered you need to forwarded using the Same Site B FXO to PSTN.
Response Signature
Yep, i want calls from SITE A to site B if not answered will get forwarded to PSTN using FXO. i think because analogphone connected to Cube by fxs port so i cant conffig ephone.
thanks
I hope you are using dialpeer for FXs port.
AFAIK it will be possible if the analogue port is configured as ephone. With dialpeer it’s not possible.
Try to register the fxs  port as sccp device using  stcapp and apply the configuration @Roger Kallberg mentioned.
Response Signature
Have a look at this blog post. It should contain what you need. http://tek-board.blogspot.com/2012/08/cme-supplementary-services.html?m=1
Response Signature
