01-07-2013 06:56 PM - edited 03-16-2019 03:02 PM
Hi all,
We configured fractional E1 on our MGCP gateway (1st 10 channels only).
My question is: Is it supported by Cisco? If any problems happen, do I get support from them? (and if possible, anyone can show me the documents/sites indicating that the feature is/is not supported?)
hoanghiep.
01-07-2013 07:06 PM
No, such is unsupported. If you want fractional T1/E1 you need to use H323.
You can search the topic in CSC and most likely find a reference link. Or search CCO for mgcp + fractional.
02-26-2013 04:38 AM
yes, jaime is correct,
also depends on the IOS version running on the H323 voice gateway. i was forced to dongrade a IOS version on a case where a fractional E1 was needed.
02-26-2013 05:39 AM
for partial E1 you need H323 gateway, it is not supported on MGCP
Anas
please rate if it is helpful
