Fractional E1 - MGCP gateway
hoanghiep
Hi all,
We configured fractional E1 on our MGCP gateway (1st 10 channels only).
My question is: Is it supported by Cisco? If any problems happen, do I get support from them? (and if possible, anyone can show me the documents/sites indicating that the feature is/is not supported?)
hoanghiep.
Jaime Valencia
No, such is unsupported. If you want fractional T1/E1 you need to use H323.
You can search the topic in CSC and most likely find a reference link. Or search CCO for mgcp + fractional.
java
if this helps, please rate
yes, jaime is correct,
also depends on the IOS version running on the H323 voice gateway. i was forced to dongrade a IOS version on a case where a fractional E1 was needed.
Anas Abueideh
Level 9
Level 9
for partial E1 you need H323 gateway, it is not supported on MGCP
Anas
please rate if it is helpful
