01-06-2011 06:49 PM - edited 03-16-2019 02:44 AM
I recently upgraded to Windows 7 64-bit from XP, and I've noticed that Freeftpd doesn't work properly anymore. The windows don't appear to render properly, for example drop-down arrows that should appear on the right side of a window are cut off. Also, the program is locking up shortly after starting it.
Has anyone found how to get Freeftpd to work with Windows 7, or could anyone recommend an alternate FTP/SFTP app?
Thanks in advance!
01-06-2011 07:38 PM
Try TFTPd32.
Please don't forget to rate our useful posts. Thanks.
02-25-2011 07:47 PM
Try using normal fonts, as of now you are using large. Hope this helps! (use a DPI of 96)
02-25-2011 08:43 PM
Filezilla is another one - not as finicky as freeftpd....
