FWUCD on MCS
Vijay Patil
Level 3
Level 3
Cisco TAC team suggest us for battery issues should be cleared up by updating the firmware.
but how we can find the current version of Firmware ..
Manish Gogna
To see what BIOS version is on a Windows-based system, you can check the following:
  • Reboot the server and hit "F1" to access the BIOS menu.
  • Optionally, you can insert the FWUCD and see if any updates are required as it detects them automatically.
To see what BIOS version is on a VOS-based system, you can check the following:
  • From the CLI, type 'show hardware' without the single quotes.
To download the firmware, navigate to the following path on cisco.com
Then select the server model followed by Voice Applications OS Firmware
Manish
Hi Vijay,
[+5] for Manish.
you can also run the command utils create report hardware from CLI . Download the same using sftp and check for firmwares.
regds,
aman
