FXO and Caller ID
JustForVoice_2
Level 4
Level 4
Hi all,
I have 3845 router added to CCM as H.323 gateway.
I am using this IOS : c3845-advipservicesk9-mz.124-3i.bin
and it contains 2 VIC2-4FXO cards.
I added the configuration :
caller-id enable
caller-id alerting ring " 2 and sometime 1"
I tried to change the cp tone and other parameters but no luck.
I used : debug vpm signal and I found:
get_fxo_caller_id:Caller ID receive failed.  parseCallerIDString:no data.
but when if I connect analog phone to the line directly I can find the caller ID.
one more thing: When I can use the command:
caller-id alerting dsp-pre-allocate
sometimes I am able to find the dsp-pre-allocate and sometimes no?
Please search first on the space before posting.
Follow the steps:
     1. Connect an analog phone and confirm if your service provider is sending the caller-id,
     2. If they are sending properly this is most likely a well known bug if you are facing on H.323 mode, upgrade the IOS to any 12.4(20)T or higher.
This post might help you!
https://supportforums.cisco.com/message/1148237
HTH.
Please rate helpful posts!
