01-05-2016 01:55 AM - edited 03-17-2019 05:24 AM
Hello Everyone,
I have a strange issue with one remote site. The setup is very simple:
CUCM è H323 GW è FXO Card.
The call is working fine for seconds or minutes, sometimes more than 10 minutes. Suddenly the call disconnects. I checked the debug I found the cause code is: Cause Value=47: resource unavailable.
However, as per my understanding of the debug the disconnect signal comes from Telco side (FXO). In addition the call use codec G711ulaw from GW to IP Phone and no MTP or transcoders are involved.
01-05-2016 01:57 AM
This is a sample from the output:
*Jan 3 8:15:01.320: htsp_process_event: [0/0/0, FXOLS_OFFHOOK, E_DSP_SUP_DISCONNECT]fxols_outgoing_sup_disc
*Jan 3 8:15:01.320: htsp_timer - 1000 msec
*Jan 3 8:15:02.320: htsp_process_event: [0/0/0, FXOLS_OFFHOOK, E_HTSP_EVENT_TIMER]fxols_disc_confirm
*Jan 3 8:15:02.320: htsp_timer_stop
*Jan 3 8:15:02.320: htsp_timer_stop2
*Jan 3 8:15:02.320: htsp_timer_stop3
*Jan 3 8:15:02.320: //208/80BA6B7C3801/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x22937820, Call Id=208
Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
*Jan 3 8:15:02.320: //207/80BA6B7C3801/CCAPI/ccConferenceDestroy:
Conference Id=0x47, Tag=0x0
01-05-2016 02:12 AM
Can you please post the show run and complete debugs which you have collect. also share the show version from VGW.
Br,
nadeem ahmed
PS: Please rate all useful post.
01-05-2016 02:54 AM
01-05-2016 02:54 AM
is it the same debug in which you were getting resources unavailable with cause_value 47?
Br,
Nadeem
01-05-2016 10:29 AM
Sorry, I have replaced the file and I added the show run.
01-05-2016 05:07 AM
Have you configured supervisory disconnect on the FXO port? If yes, please don't use "anytone". Also can you share voice port configuration. If using custom cptone then make sure you are using the correct disconnect frequency and cadence. Invalid values might cause abrupt call disconnect like this.
01-05-2016 10:34 AM
I'm using the following configuration under the port
voice-port 0/0/0
trunk-group OutGoing
supervisory disconnect dualtone mid-call
cptone BE
timeouts initial 5
timeouts interdigit 3
timeouts call-disconnect 3
timeouts ringing 5
timeouts wait-release 1
timing hookflash-out 500
timing guard-out 300
impedance complex2
caller-id enable
as you can see I'm using dual tone.
when I saw this line during my troubleshooting:
I removed this line from the configuration :
But I had FXO disconnect issue, " line keeps off hook"
01-12-2016 07:52 AM
You can see "E_DSP" which means DSP detected a disconnect tone.There are two options you can try
1. Configure a custom CPTONE instead of standard CPTONE for disconnect. I need packet capture to find out correct disconnect tone. Remove dual tone command make a call and disconnect the call from PSTN side. The IP phone will hear a disconnect tone. Can you capture this tone using wireshark by connecting PC on the back of phone? I can tell you correct frquency and cadence if you can provide the capture
2. change the CPTONE from BE to something else. For ex; BR
01-06-2016 01:31 AM
Hello, I recorded the disconnection tone and I added a custom cp-tone. still the same issue but the disconnect cause now: 86
//296/D0035D9B8150/CCAPI/cc_api_call_disconnected:
Cause Value=86, Interface=0x22937820, Call Id=296
any idea?
01-03-2017 06:18 AM
Yoo cheking FXO port connector pinout. Because cannot open FXO port and The FXO port does not have enough power . You rebuild connector jack.
