fxo conected to a Huawei LTE
Rafael Jimenez
Level 4
Level 4
I have a huawei lte e5172 router. It come with a telephone jack. An analog phone connected to this port works fine.
My problem is if I connect this port to an fxo port in a cisco 2801 router.
The 2801 with the vic card do not detect that there is a line connected to it. not possible inbound nor outbond calls.
The fxo port is fine, if I connect another line from the pstn or to a sip gateway works fine.
Both the LTE modem and the fxo port in the 2801 works with other brands but not between them.
I need some help with this.
Thanks.
10 Replies 10
CHRIS CHAMBERS
have you tried both loop start and ground start signalling?
Router(config)# voice-port slot/subunit/port
Router(config-voiceport)# signal loop-start | ground-start
http://www.cisco.com/en/US/docs/ios/12_2/voice/configuration/guide/vvfport.html#wp1054950
Groud start is only for certain special order lines in the USA. It does not apply to any other situation.
Hello Chris, its me, Rafa!.
Yes, I done everything, but nothing works with this LTE modem.
I have done the same with other analog lines and with other cable-modem with fxs ports connected to the 2801 and works fine.
paolo bevilacqua
"debug vpm signal" with "term mon".
Sometimes the outgoing calls goes well, but for incoming calls the caller only hear the ring tone, but the router never answer.
the port configuration is:
voice-port 0/1/1
connection plar 5000
caller-id enable
this is the debug command which shows a succesfull outgoing call:
Aug 14 19:47:23.064: htsp_timer_stop3 htsp_setup_req
Aug 14 19:47:23.068: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Aug 14 19:47:23.068: [0/1/1] set signal state = 0xC timestamp = 0
Aug 14 19:47:23.068: htsp_timer - 1300 msec
Aug 14 19:47:23.268: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_0100]fxols_disc_clear
Aug 14 19:47:23.272: htsp_timer_stop2
Aug 14 19:47:23.272: htsp_timer - 1300 msec
Aug 14 19:47:23.320: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Aug 14 19:47:23.324: htsp_timer2 - 1000 msec
Aug 14 19:47:23.324: htsp_timer_stop
Aug 14 19:47:24.324: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
Aug 14 19:47:24.324: htsp_timer_stop
Aug 14 19:47:24.324: htsp_timer_stop2
Aug 14 19:47:24.324: [0/1/1] set signal state = 0x4 timestamp = 0
Aug 14 19:47:24.328: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
Aug 14 19:47:24.596: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Aug 14 19:47:24.596: htsp_timer - 125 msec
Aug 14 19:47:24.724: htsp_process_event: [0/1/1, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Aug 14 19:47:24.724: htsp_timer - 10000 msec
Aug 14 19:47:24.724: htsp_timer3 - 5600 msec
Aug 14 19:47:24.724: [0/1/1] htsp_start_caller_id_rx:BELLCORE
Aug 14 19:47:24.724: htsp_start_caller_id_rx create dsp_stream_manager
Aug 14 19:47:24.724: [0/1/1] htsp_dsm_create_success  returns 1
Aug 14 19:47:30.324: htsp_process_event: [0/1/1, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
Aug 14 19:47:30.324: htsp_timer_stop3
Aug 14 19:47:34.724: htsp_process_event: [0/1/1, FXOLS_RINGING, E_HTSP_EVENT_TIMER]fxols_ringing_disc
Aug 14 19:47:34.724: htsp_timer_stop3
Aug 14 19:47:34.724: [0/1/1] htsp_stop_caller_id_rx. message length 0
Aug 14 19:47:34.724: [0/1/1] htsp_dsm_close_done
there is no debug output for the incoming call.
You can try configuring a different cptone, however the debug indicates many problems including no loop current and ringing detected while doing an outgoing calls, so likely that is not going to work anyway.
Its a wierd problem related with the LTE modem. This modem has voice system based in SIP.
supposedly it has a normal fxs port, but there are several problems, for example if the outgoing call goes fine, the following problem is the dtmf.
I have to talk with the provider to see how solve those issues.
They will lilkely tell you that if a phone works, their responsability ends there.
The provider said that may be is a problem with the 48Volts, because the LTE modem use a 9V AC/DC adapter, and its possible that this device is not able to produce the range of voltages requiered by the vic2 fxo port.
Something weird happened, I confiured the fxo port (in UC520) with anwer supervision (supervisory answer dualtone & supervisory disconnect dualtone mid-call). It worked for several attempts. After that has been imposible get this work again.
With the 2801 It never worked.
Telephony devices use DC-DC converters. They can produce an higher voltage than the power supply, even if not full 48v. However whatever it does, it is not good enough for the 2801.
