I am configuring the CME ver 8.6 for FXO ports.My customer has 4 FXO Ports and 1 T1/E1 card.The requirement is..once the PRI goes down then all the calls coming to recpetion should land on the FXO and it should ring on reception phone.My current recpetion number is 1000( its pilot number for PRI range).The configuration I've done is and it is not working fine.Is there anything as well which needs to be taken care.
voice-port 1/0/12
signal ground-start
incoming alerting ring-only
ring number 3
trunk-group VIC2-2FXO
connection plar-opx 1000
end
voice-port 1/0/13
signal ground-start
ring number 3
end
dial-peer voice 111 pots
trunk-group VIC2-4FXO
destination-pattern "FXO pstn number from which call will come"
incoming-called number
ephone-dn 27 dual-line
number 1000 secondary 6901000
description 6901000
name Board Line
