07-28-2015 04:46 AM - edited 03-17-2019 03:47 AM
Experts,
I have a Router with a PVDM3-16 and 4 FXO/FXS, When i call from Provider Side to the GW i don't see any debugs on the GW level, Just as the call don't come to the GW,
When connecting the RJ11 from the provider side to analogue phone the calls work fine !.
the only debugs i had collected is when calling the provider from an internal analogue phone ()
Calling number : 210
Called number : 00962 791432232
All the calls are down at the moment, Could you please check the debugs and let me know if anything that can be done here.
Thanks and Regards,
Nash
07-28-2015 07:26 AM
share running config
07-29-2015 01:59 AM
07-29-2015 04:51 AM
what ports are fxs and what fxo? I suppose fxo 0/0/0 and 0/0/1
sh ver
sh inv
sh voice-port 0/0/0
sh voice-port 0/0/1
sh voice-port 0/0/2
sh voice-port 0/0/3
and where is phone whith number 2110. I dont see it
ephone-dn 4 dual-line
no corlist outgoing CSS-International
number 203 should ring
07-29-2015 05:44 AM
Thanks for your response,
Calling number is 210 not 2110
get_local_station_id calling num=210 calling name=Amjad Hamayel calling time=07/28 13:20
ephone-dn 9 octo-line
number 210
pickup-group 1
label Amjad Hamayel
name Amjad Hamayel
please find the show output as requested attached
07-29-2015 06:13 AM
Can you enable "voice iec syslog" and turn on terminal monitor and then make a call. The system will produce a reason code for the failed call.
07-28-2015 08:20 AM
It is very hard to say without looking at the Config what is actually going on.
However have you configured the plar opx on the FXO ports?
07-29-2015 01:56 AM
07-28-2015 06:51 PM
I think you are running debug voip ccapi inout..as I can see the calling number.
This is a non isdn call so first you can't give a debug isdn q931 on gw and you have to work with either debug voip dial-peer inout or debug voip ccapi inout.
07-29-2015 01:57 AM
Am running the following debugs
voip ccapi inout
vpm all
hpi all
07-29-2015 05:24 AM
Nash,
You have to turn off "no ip address trusted authenticate" or add the trusted IP addresses to the "ip address trusted list". Also verify that your monitor logging is set to "debugging".
Yosh
