09-10-2013 12:20 PM - edited 03-16-2019 07:17 PM
Dear All
I need an urgent help
I’m using CME Ver 8.6 and unity express running on sm-sre-710-k9 at Saudi Arabia
If someone call our land line, call redirect to auto attendant if only no one answer, EXT keep ringing and fxo port stay on
voice class custom-cptone 2
dualtone disconnect
frequency 425
cadence 500 500
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone 2
cptone BR
timeouts call-disconnect 0
connection plar opx xxx
caller-id enable
09-14-2013 03:38 PM
this is a well known issue in FXO setup. the disconnect signal it depends on the PBX you are connected from PSTN provider. the disconnect signals are different from one vendor to other, Ericson, Siemens, Alcatel,... etc.
You need to take the appropriate disconnect signal from your PSTN provider if it is possible.
you can use the following link to look for your current disconnect signal
http://www.3amsystems.com/wireline/tone-search.htm?start=0&kCountry=92&kTone=10
if one of the above is not working you need to take pcm captures, find the below link
http://ciscoflair.blogspot.com/2009/05/cisco-fxo-disconnect-issue.html
to take pcm capture use the following command
1. Enable the capture:
Router(config t)#voice hpi capture buffer 5000000
Router(config t)#voice hpi capture destination flash:FileName.pcm.dat
2. Start the capture:
Router#test voice port x/y/z pcm-dump caplog 7
3. Place a call on that port, and disconnect from the far end.
4. After the call has been disconnected from the PSTN side, disable the capture with the command below.
Be sure to do this, or otherwise the router flash will be full and the router will hang.
Router#test voice port x/y/z pcm-dump disable
Router(config t)#no voice hpi capture destination
5. Please send me this .dat file with the bad capture so I can extract it into PCM audio files.
Anas
please rate all helpful posts
09-14-2013 03:39 PM
Hi Ismaeel,
also take a look for the following thread
https://supportforums.cisco.com/message/3883674#3883674
Anas
please rate all the helpful posts
11-07-2014 12:45 AM
Did u get a solution? facing same problem now. really appreciate your help. :)
10-11-2015 02:56 AM
voice class custom-cptone STC
dualtone disconnect
frequency 398
cadence 502 497
sorry i was out
11-02-2023 03:51 AM
this is the nearest parameter so far ----> i give you 5 star ---> * * * * *
11-02-2023 10:57 PM
11-02-2023 10:57 PM
You can find the exact frequency as well that is being received from Service Provider. I have a article in Support Forum: https://community.cisco.com/t5/collaboration-knowledge-base/troubleshoot-audio-issues-and-fxo-disconnect-issue-using-pcm/ta-p/3926564
11-03-2023 09:24 AM
Experiencing FXO not disconnection issues can be same as frustrating as a delayed birth certificate attestation process. Both can leave you hanging, waiting for resolution.
