07-27-2016 10:54 AM - edited 03-17-2019 07:39 AM
Hello all ,
I have configured and FXO ports on a 2901 gateway as an MGCP and everything is going fine except the caller ID giving me as "Call from Unknown Number" so I check the configuration page of FXO and enable caller ID but now it gives me as "Call from O" from any phones trying to call from outside.
Any one face this problem before with MGCP because I heard that MGCP not support caller ID with FXO but I found that this issue was on the version before 8.5 and I am using 10.5.
07-27-2016 11:12 AM
So, you enabled "Enable Caller ID" checkbox on the port?
What country is this in?
Can you post "debug vpm signal"?
07-28-2016 10:11 AM
The country is qatar (Middle East) , I will post you the output once I go to the office again next week
01-08-2017 02:20 AM
You issue resolved .Kindly get me the fix if you got it right.
Thanks in Advance
