FXO pstn call issue
frank3333
I have connected 4 pstn lines to vic2-4fxo on  2921 GW router (h.323) and tried to dial my cucm extension (connection plar 2100).
i cant see any debug output  for (isdn q931, vpm signal,  voip ccapi inout). and when dialing from outside to pstn number which assign with fxo ports
ports are always on hook  and drom with "sh voice port summary" command.
tried with both loop and ground signalling.
dial-peer configured for both outgoing and incoming.
config is attached.
Help me to resolve this.
logging on , logging monitor debugging configured.
Thanks.
13 Replies 13
soloo2014
connect the lines to an analog handset to check if you are getting signal.
because u should get the off-hook status when issuing the
regardless of the dial-peers
Hi Soloo,
i am able to dial and received calls when use analog handset.
try changing the vic2-4fxo to a different slot on the router
Thanks solo
will do and let you know.
Changed the slot still same no debug output and  voice port summary still drom/idel/on hook.
No green lights when dial to these numbers.
is there any issue with dsp? but i can configure voice-port.
we have E1 card but currently not using it all port are kept down.
Any suggestion plz.
Hi Frank.
Try to enable debug at monitor level.
logging buffered 4096
end
debug vpm all
term mon
See if you see something during a terminal session and during an outgoing all.
Let us know.
regards
Carlo
Please rate all helpful posts "The more you help the more you learn"
Tried,
But no luck.
Hi Frank.
Please activate a debug voip dialpeer inout and post the output.
check also a show log
Carlo
I can't see any debug output when im dialing to the DID.
show log -
Oct 20 15:17:11.838: %SYS-5-CONFIG_I: Configured from console by console
Oct 20 15:17:11.854: %SYS-5-CONFIG_I: Configured from console by console
Oct 20 15:17:11.870: %SYS-5-CONFIG_I: Configured from console by console
Oct 20 15:17:12.014: %SYS-5-CONFIG_I: Configured from console by console
Oct 20 15:17:12.026: %SYS-5-CONFIG_I: Configured from console by console
Oct 20 15:17:12.158: %CMAPP-6-CONFIG_DONE: Configuration by CCM is done
Oct 20 15:18:33.598: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/2/0, ch        anged state to Administrative Shutdown
Oct 20 15:18:33.598: %SYS-5-CONFIG_I: Configured from console by console
Oct 20 15:18:33.610: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/2/0, ch        anged state to up
Oct 20 15:18:33.610: %SYS-5-CONFIG_I: Configured from console by console
Oct 20 15:18:33.742: %CMAPP-6-CONFIG_DONE: Configuration by CCM is done
Oct 20 15:21:01.634: %MGCP_APP-6-MGCP_SHUTDOWN_COMPLETE: MGCP Shutdown has compl        eted
Oct 20 15:21:04.798: %SYS-5-CONFIG_I: Configured from console by vty0 (172.17.10        1.110)
Oct 20 15:24:04.698: %SYS-5-CONFIG_I: Configured from console by vty0 (172.17.10        1.110)
Oct 20 15:25:00.338: %SYS-5-CONFIG_I: Configured from console by vty0 (172.17.10        1.110)
 ( i tried with mgcp and disable it before testing).
Can you please post the output of first lines of a show logg command such as  Console logging: level debugging  482 messages logged, xml disabled,?
Carlo
Thanks for your continuous support.
Syslog logging: enabled (0 messages dropped, 25 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 77 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
        Logging to: vty388(0)
    Buffer logging:  level debugging, 100 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 102 message lines logged
        Logging Source-Interface:       VRF Name:
If you have a free time i can open team viewer session.
Hi Frank.
You're most welcome :)
Send me a PM with TV code and pwd
Carlo
code - 789 104 171
 pwd- 3038
