01-30-2008 04:00 PM - edited 03-15-2019 08:32 AM
I am working with 8 analogues lines for a UCME / H323 gateway (Cisco 2811). I know the Telco can configure the 8 lines in a rotary upon request but in the event that they are not. Are there any configurations on the voice ports for especially for outbound calls.
Kind regards,
Richard.
01-31-2008 03:01 AM
Use the preference command under the POTS dial peers to set up a order of outbound hunting. Preference 0 is the default, so it does not show in the config, so leave it off your first dial peer, then add preference 1-9 for the other dial peers.
01-31-2008 03:13 AM
voice-port x/y/z
trunk-group pots
dial-peer voice 9 pots
destination-pattern 9T
trunkgroup pots
This allows you to configure a single DP to control all lines. You can also set other properties under "trunk group pots"
