05-29-2013 02:29 AM - edited 03-16-2019 05:34 PM
Hello All,
I have done the requisite searches but none address my specific query.
My query i have a Cisco 2801 router with FXO ports connected to a Huawei FT2250 Fixed line terminal. I am able to make a CSIM START XXXXXXX out of the port but the call disconnects after a couple of seconds. Secondly i have configured connection plar XXX to automatically dial a number, when i make an inbound call into the router the call is disconnected after a couple of seconds.
I have tried various configurations settings but the problem persists.I await your enlightened responses.
05-29-2013 02:38 AM
try under voice port
no battery reversal
05-29-2013 02:44 AM
Hi Paolo,
I've tried that and it doesnt work either, disconnects after a couple of seconds.
KA
05-29-2013 03:19 AM
Check that device interface is FXS, to be connected to FXO.
05-29-2013 04:32 AM
This has also been confirmed.
05-29-2013 04:39 AM
Then you can take "debug vpm signal". Possibly you will see "power denial" meaning device is not supplying loop current in off-hook state.
05-29-2013 05:23 AM
Hi Paolo,
You are a right i have seen the output as mentioned. What is nextto remedy this.
*May 29 12:05:34.342: htsp_process_event: [0/1/2, FXOLS_PROCEEDING, E_HTSP_PRE_CONN_DISC]
*May 29 12:05:40.326: htsp_process_event: [0/1/2, FXOLS_OFFHOOK, E_HTSP_EVENT_TIMER]fxols_disc_confirm
*May 29 12:05:40.326: htsp_timer_stop
*May 29 12:05:40.326: htsp_timer_stop2
*May 29 12:05:40.326: htsp_timer_stop3
*May 29 12:05:40.326: htsp_process_event: [0/1/2, FXOLS_POWER_DENIAL, E_HTSP_RELEASE_REQ]fxols_offhook_release
05-29-2013 05:40 AM
You can test the device with a regular telephone.
Other than that, nothing can be done on the Cisco.
05-29-2013 05:43 AM
I already did that before and it was working fine. However the thing is, it was working before we moved it to a new router of similiar specs, so how do you explain this anomaly.
Secondly if nothing can be done on the Cisco, what can be done on the Huawei device.
05-29-2013 12:22 PM
Sorry, I don't know.
