FXS module hot swap
ramon.yu.jr
hi, is the FXS module EVM-HD-8FXS/DID hot swappable?  i don't see it clearly stated in its white paper.  or i may have just overlook or misread it.  pls help confirm and cite the reference.  thanks.
regards,
ramon
3 Accepted Solutions
Payal Bhaduri
Hi Ramon,
The EVM-HD-8FXS/DID is not hot swappable. The router has to be shutdown.
paolo bevilacqua
Which router do you have ?
ISR G1 do not support hotswap.
ISR G2 does.
amitsin
Ramon,
How do you plan to connect this module "EVM-HD-8FXS/DID" and which router Model?
     ++ You might be inserting it into router using NM or NME as EVM ports are available only on 2821 and 2851 routers:
http://www.cisco.com/en/US/prod/collateral/modules/ps2617/prod_qas0900aecd8016c487_ps5854_Products_Q_and_A_Item.html
++ In ISR G1 Routers range only 3845 is capable of OIR(Hot Swap):
http://www.cisco.com/en/US/partner/docs/routers/access/3800/hardware/installation/guide/38netmod.html
++ In ISR G2 only 3900 series is capable of OIR (Hot SWAP):
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/sre_v/1.5/user/guide/hardware.html
Note* in ISR G2 you will have to use SRE module, in order to connect any NM/NME module.
Amit Singh
7 Replies 7
Payal Bhaduri
Hi Ramon,
Thanks Payal
paolo bevilacqua
ISR G2 does.
I have 2821 which is ISR G1   Thanks Paolo
amitsin
Ramon,
Amit Singh
amitsin
Just to Add further:
++ The following items use OIR in the Cisco 3925 and Cisco 3945 ISRs:
•Service Modules
•Network modules
**Caution**
The Cisco 3845 and 3845-NOVPN router supports OIR with similar modules only. If you remove a network module, along with any installed WAN or voice interface cards, install another module and card combination exactly like it.
Same holds true for 3900 Series Routers.
Amit Singh
Thanks Amit
