Gateway VG320 mgcp config. error
ciscoceci
i have to configure a gateway Vg320 over CUCM 10.5, anyone could give an example configuration?
When i configure  the CUCM config doesn´t download to the gateway,
I can see the below error when i write "sh ccm-manager config-download"
CCM MANAGER APPLICATION IS NOT CONFIGURED
Thanks Anna.
Dennis Fogler
Sounds like you might be having an ip address to name resolution issue on the VG.   Try putting an "ip host" entry in the VG for Communications Manger.
Let me know if this helps.  -Dennis
Jaime Valencia
And exactly what have you configured in the GW???
java
if this helps, please rate
Thanks Dennis, Jaime,
The problem was that i have configured in CUCM web (Device config) a domain name as "xxxxxx.com" and the correct is "gw.xxxxx.com"
thanks.
Dennis Fogler
