Generate Call Report in CUCM
prakashsatya
Is it possible to take report of number of incoming Call/Outgoing calls/Missed calls for a particular extension in CUCM ? or using any other method.
Thanks ,
-Satya
Jaime Valencia
Assuming you have CDR enabled on your servers, yes, you can use CAR for that
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/12_0_1/car/cucm_b_cdr-analysis-and-reporting-1201.html
If you do not have CDR enabled, no way to get records until you enable it, and you only get info from that point going forward.
java
if this helps, please rate
Jaime Valencia
java
VoIP Engineer
The builtin CAR is probably the quickest way to get your answer, however if you are looking for other options, you could checkout VoIP Detective.  There is a free version that will give you call reports on any call across your cluster for the previous 7 days.
VoIP Detective call reporting
