Showing results forĀ
Search instead forĀ
Did you mean:Ā
Getting Disconnect From Service Provider.
Shobhit Sinha
Below are the logs from Gateway ; we are dialing 2 numbers XXXXX443491 and XXXXX442777.
XXXXX42777 --> this is working and XXXXX443491 is not working.
Problem: We are able to dial XXXXX442777 but not XXXXX443491.Below are the logs from Gateway.
Jan  9 12:40:52 GMT: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xB
738
        Channel ID i = 0xA98388
                Exclusive, Channel 8
Jan  9 12:40:52 GMT: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00E5
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x00C3, N/A
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, ' XXXXX443491
Jan  9 12:40:52 GMT: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8
0E5
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Jan  9 12:40:52 GMT: ISDN Se0/1/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x80
E5
Jan  9 12:40:52 GMT: ISDN Se0/1/0:15 Q931: TX -> PROGRESS pd = 8  callref = 0xB7
38
Jan  9 12:40:56 GMT: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x
80E5
        Cause i = 0x8A9C - Invalid number format (incomplete number)
Jan  9 12:40:56 GMT: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x
B738
Jan  9 12:40:56 GMT: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x373
8
Jan  9 12:40:56 GMT: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0xB738
Jan  9 12:40:56 GMT: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00E
Jan  9 12:40:56 GMT: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x80E5
Jan  9 12:41:09 GMT: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00E6
        Sending Complete
                Standard = CCITT
        Calling Party Number i = 0x0081, '1386425544'
        Called Party Number i = 0x80, 'XXXXX442777
Jan  9 12:41:09 GMT: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8
0E6
Jan  9 12:41:09 GMT: ISDN Se0/1/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x80
E6
Jan  9 12:41:11 GMT: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x80
E6
        Progress Ind i = 0x8482 - Destination address is non-ISDN
Jan  9 12:41:24 GMT: ISDN Se0/1/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x80E
6
        Connected Number i = 0x00C3
Jan  9 12:41:24 GMT: ISDN Se0/1/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0
x00E6
738
        Sending Complete
                Standard = CCITT
        Called Party Number i = 0x80,  XXXXX443491
0E5
E5
38
80E5
B738
8
0xB738
0x80E5
        Sending Complete
                Standard = CCITT
        Calling Party Number i = 0x0081, 'XXXXX25544'
        Called Party Number i = 0x80, XXXXX442777
0E6
E6
E6
6
x00E6
Well ur ISP tells you the number is invalid or incomplete are you sure that number is in working order and are you sure you are sending called and calling info the format ur ISP expects it?
Best Regards
Manish Prasad
Level 5
Level 5
Hi Shobhit,
You are not sending correct caller ID to you Telco when you dial XXXXX443491. Please verify this.
Rate all the helpful post.
Manish
