GSM modem over MGCP
Hi I cant place a call to a gsm modem, I have seen a similar post, but the person is using H.323, im my case we are using MGCP, but i cand find any Information about it., if run a debug.this is what i got, Im believe that is not possible, but id like to have a confirmation.
DXAMEGM01#
Oct 22 15:19:05.009: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x1484
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
        Calling Party Number i = 0x0081, '02636090'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '999651716840'
Oct 22 15:19:05.041: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x9484
DXAMEGM01#
Oct 22 15:19:06.949: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x9484
        Cause i = 0x82C1 - Bearer capability not implemented
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Thanks in advance.
Cesar
afmmanicke
It may be better to use the following debug:
debug voip ccapi all
You should implement this on your PSTN gateway as well as any other analog gateway along the call path.
Post your results on your test call calls.
TONY
Hi Tony, i did several test call and im allways getting "ccCallDisconnect:" as first message, on top of that, I have to clue about what to look for.
//172464/FC256C3E90D7/CCAPI/ccCallDisconnect:
   Start Calling Accounting;
   Call Entry(Incoming=FALSE)
Oct 23 06:37:48.415: //172464/FC256C3E90D7/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Oct 23 06:37:48.415: //172464/FC256C3E90D7/CCAPI/cc_api_get_transfer_info:
Oct 23 06:37:48.419: //172464/FC256C3E90D7/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Oct 23 06:37:48.419: //172465/FC256C3E90D7/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Oct 23 06:37:48.427: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif:
   ExpectFactor=0xA
Oct 23 06:37:48.427: //172465/FC256C3E90D7/CCAPI/cc_api_insert_call_history:
Oct 23 06:37:48.427: //172465/FC256C3E90D7/CCAPI/ccGetCallActiveByCallID:
Oct 23 06:37:48.427: //172465/FC256C3E90D7/CCAPI/cc_decr_if_call_volume:
   Remote IP Address
   Total Call Count=4, Voip Call Count=4, MMoip Call Count=0
Oct 23 06:37:48.431: //172465/FC256C3E90D7/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x490AD6F4, Tag=0x0, Call Id=172465,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Oct 23 06:37:48.431: //172465/FC256C3E90D7/CCAPI/cc_disconnect_notify:
Oct 23 06:37:48.431: //172465/FC256C3E90D7/CCAPI/callStackPop:exit@4869
   Call Disconnect Event Sent
Oct 23 06:37:48.431: //172465/FC256C3E90D7/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
Oct 23 06:37:48.431: //172465/FC256C3E90D7/CCAPI/cc_delete_guid_pod_entry:exit@1165
Oct 23 06:37:48.431: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Oct 23 06:37:48.431: :cc_free_feature_vsa freeing 49E9D448
Oct 23 06:37:48.431:  vsacount in free is 9
Oct 23 06:37:48.431: //172465/FC256C3E90D7/CCAPI/cc_delete_call_entry:
   Total Call Count=5, Call Entry(Call Count On=TRUE, Incoming Call=FALSE)
   Total Call Count=4
Oct 23 06:37:48.443: //172464/FC256C3E90D7/CCAPI/cc_api_insert_call_history:
Oct 23 06:37:48.443: //172464/FC256C3E90D7/CCAPI/ccGetCallActiveByCallID:
Oct 23 06:37:48.443: //172464/FC256C3E90D7/CCAPI/ccGetCallActiveByCallID:exit@12577
Oct 23 06:37:48.455: //172464/FC256C3E90D7/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A090058, Tag=0x0, Call Id=172464,
Oct 23 06:37:48.455: //172464/FC256C3E90D7/CCAPI/cc_disconnect_notify:
Oct 23 06:37:48.455: //172464/FC256C3E90D7/CCAPI/callStackPop:exit@4869
Oct 23 06:37:48.455: //172464/FC256C3E90D7/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
Oct 23 06:37:48.455: //172464/FC256C3E90D7/CCAPI/cc_delete_guid_pod_entry:exit@1165
Oct 23 06:37:48.455: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Oct 23 06:37:48.455: :cc_free_feature_vsa freeing 49E9DEC8
Oct 23 06:37:48.455:  vsacount in free is 8
Oct 23 06:37:48.455: //172464/FC256C3E90D7/CCAPI/cc_delete_call_entry:
   Total Call Count=4, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
   Deleting profileTable[0x4A7C7058]
DXAMEGM01# : //172464/FC256C3E90D7/CCAPI/ccCallDisconnect:
   ExpectFactor=0xA
   Remote IP Address
   Incoming=FALSE
   Total Call Count=4
   Incoming=FALSE
DXAMEGM01#
