11-07-2015 03:26 AM - edited 03-18-2019 11:41 AM
Hi all,
I use CME version 15.5(1)T2. I want to configure GUI. when I configure that in telephony-service by:
web admin system name root password root1
time-webedit
in navigator when i type http://192.168.1.129/ccme.html and type username & password I got a blank page
Where is problem?
Thank you in advance
11-07-2015 09:54 AM
Below are the steps you need to check and confirm to access the CME gui.
> ip http command should be there.
> please count the number files it should 18.
> if still having issue re-copy the file to flash one by one totals number of file should be 18 .
How to Configure Web on CME for GUI.
GUI Files
A tar archive contains the files that you need to use the Cisco Unified CME graphical user interface (GUI), which provides a mouse-driven interface for provisioning phones after basic installation is complete
SUMMARY STEPS
DETAILED STEPS
Step 1 Go to http://www.cisco.com/cgi-bin/tablebuild.pl/ip-key .
Step 2 Select the file to download.
Step 3 Download zip file to tftp server.
Step 4 Use the zip program to extract the file to be installed, then:
Router# copy tftp://x.x.x.x/P00307020300.sbn flash:
Router# archive tar /xtract tftp:///cme-gui-124-24T.tar flash:
Step 5 Verify the installation. Use the show flash: command to list the files installed in in flash memory.
Step 6 Then enable http server
ip http server
ip http authentication local
ip http path flash:/gui
telephony-service
web admin system name <abc> password <xyz>
Br,
nadeem
PS: Please rate all useful post.
11-09-2015 12:45 AM
Thank you Nadeem will try that
11-09-2015 03:27 AM
you should also add the dn-webedit command
11-09-2015 01:28 AM
Hi Nadeem,
what is the GUI Version is compatible with CME 15.5(1) T2 version ?
