04-08-2011 10:40 PM - edited 03-16-2019 04:25 AM
The 2911 router is already configured as an H.323 gateway to CUCM8.5.
I'm planning to configure this same router as H.323 gatekeeper, both CUCM and the H.323 gateway (same box) will then register to it. I have an H.323 device that has to register to a gatekeeper. The IOS version of router is 15.0.
Any input is appreciated!
Jonathan
04-09-2011 04:38 AM
The below two docs should help you in configuration
Check this doc for gatekeeper concepts
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a00800c5e0d.shtml
Hope that helps
Nitesh
PS:Pl rate helpful posts
04-11-2011 10:17 AM
thanks for the info, Nitesh. i've worked on every piece of them, cucm, h323 gw, h323 gk, just not sure if h323 gw & gk can cowork on a single router. i heard that h323 gk should use a router alone a few years ago, however that restriction might be related to old ios version.
04-11-2011 10:33 AM
That was a problem in CUCM version 4.x. Don't think you should face a problem in the later versions.
Hope that helps
Nitesh
PS:Please rate if this helps
