Is there anyway to choose which FXO to go out based on the calling extension?
hxmengmetro
Hi All,
We have 4 FXO ports in our router. Two departmens are using the same router. I want them to use different lines to reach out. Is there anyway like PBR in the router for the voice ports? So like say any internal extension 19xx will use FXO port 0 and 1. The other extension will use port 2 and 3.
Thanks for the help.
Lou
paolo bevilacqua
Are you using CM or CME?
In either case the question is asked frequently so you would find an answer by using the search function to the to right of the screen.
I'm using the CM. But it will switch to CME during SRST. Let me search around here. Thanks for the reminder.
Lou
I searched around and found the solution is to add a Prefix to the route pattern. Assign the extensions to different CSS. So when CM pass the dialing digits to the router, does the router strip the prefix automatically or the router need do that? Thanks.
Lou
