02-02-2007 10:11 AM - edited 03-14-2019 07:51 PM
I configured h323 gateway in the callmanagaer 4.X, but the gateway isn't registered. What is problem?
My h323 gatewy appoint to another h323 192.168.1.119
The gateway was MGCP.
02-02-2007 10:46 AM
You are missing the following commands under dedicated intereface:
interface x/x
h323-gateway voip interface
h323-gateway voip h323-id "anything"
h323-gateway voip bind srcadd "ip add of the interface"
HTH, please rate all posts!
Chris
02-02-2007 11:08 AM
IP add of CCM or another h323 gateway?
02-02-2007 11:20 AM
What do you mean another GW?
If you need to use a remote GW for processing the calls then you dont need anything on the GW.
The IP address should be local to the router, etiher loopback or FA interface.
Chris
02-05-2007 11:42 AM
HI Cris.
All my calls are sent for another gw
Then I want to add my Router 2801 as my gw of the callmanager 4.x so that all the external calls to CCM aresent for HiPath 3800.
PSTN <--> Siemens HiPath 3800 <-> LAN - Router2801 - CCM 4.x
02-05-2007 12:14 PM
You control the routing via Route Pattern in CCM, here is what to do:
1. configure the router as GW:
interface x/x
Not sure if you have a PRI controller card and available T1 port on Siemens, but in order to do the integration, you'll need both. Your best bet would be to configure QSIG as the isdn switch-type, but you can really use any protocol.
2. Add pots-dial peers for outboud calling from CCM to Siemens, such as:
dial-peer voice 1 pots
incomaing called-number .
direct-inward-dial
destination-pattern 9!
port 1/0:23 (D-channel of PRI)
3. add voip dial-peers for calls from Siemens to CCM
dial-peer voice 100 voip
destination-pettern 2... (assuming 2XXX are the DN on CCM)
session-target ipv4:
codec g711ulaw
no vad
4. Configure H.323 GW on CCM
5. Create Route Group and point to the GW
6. Create Route List and point to the Route Group
7. Create Route Patterns and point to the RL
For more help you want to reseach PBX integration, one resource can be
http://www.cisco.com/warp/public/779/largeent/avvid/inter_operability/flash/portal.html
or simply search this formum , there's been ton of threads about PBX integration to CCM.
Chris
02-06-2007 02:39 AM
Hi Chris
Thank you very much!
The Siemens PBX and CCM are connected through LAN (Ethernet)and not through T1/E1.
02-06-2007 02:55 AM
