H323 gateway not registering.
Rajan R
Hey Guys,
Trying to add a h323 gateway on CUCM but it doesnt register. below is the gateway configuration. What am i missing ?
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
clock timezone INDIA 5 30
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
ip dhcp excluded-address 10.200.120.1 10.200.120.100
ip dhcp pool Voice
network 10.200.120.0 255.255.252.0
default-router 10.200.120.1
option 150 ip 10.200.120.6
ip domain name yourdomain.com
no ipv6 cef
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-812656642
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-812656642
revocation-check none
rsakeypair TP-self-signed-812656642
crypto pki certificate chain TP-self-signed-812656642
certificate self-signed 01
BE34C4D6 86BD9F8E 886FC936 99
      quit
voice-card 0
voice call disc-pi-off
voice rtp send-recv
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g722-64
codec preference 4 g729r8
video codec h264
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 10
rule 1 /^6748/ //
voice translation-profile OUTGOING
translate called 10
license udi pid CISCO2921/K9 sn FGL
license accept end user agreement
license boot module c2900 technology-package securityk9
hw-module pvdm 0/0
file privilege 0
username admin privilege 15 secret
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/0/1
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Embedded-Service-Engine0/0
no ip address
interface GigabitEthernet0/0
ip address 10.200.120.1 255.255.252.0
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn sending-complete
no cdp enable
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 180 life 180 requests 86400
ip route 10.200.120.0 255.255.252.0 GigabitEthernet0/0
control-plane
voice-port 0/0/0:15
mgcp profile default
dial-peer voice 1 pots
translation-profile outgoing OUTGOING
destination-pattern 0.T
incoming called-number .
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 2 voip
destination-pattern .
session target ipv4:10.200.120.6
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
gatekeeper
shutdown
scheduler allocate 20000 1000
ntp master
end
daniel.bloom
H323 gateways don't actually register to CUCM.
Aman Soi
Hi Raju,
H.323 is a peer to peer protocol.It would always shows STATUS as UNknown in Call Manager while MGCP shows status as REGISTERED in Call Manager.
regds,
aman
Hi Raju,
Please refer the link for H.323 config.
I do not find ethernet config and also the commands need to be configured under ethernet port of router
h323-gateway voip interface
h323-gateway voip bind srcaddr
http://uctime.blogspot.in/2012/08/h323-gateway.html
regds,
aman
islam.kamal
Level 10
Level 10
Hello
Kindly find the below
interface giga 0/0
Make sure that you can ping your CUCM IP.On CUCM  (gateway -h323 gateway after the you put the IP of your router do not forget to do reset ) .
Thank you
please rate if this will help
