01-10-2021 04:08 AM
I want to implement voice gateway for one of the branch site . They have PRI connection.
Can I use SIP trunk between CUCM and Voice gateway. then In VG, I configure PRI configuration and required dial peer for calls?
can I do that way?
What all configuration I have to follow to do above setup if that possible?
Since this is branch site, Im planning to implement SRST as well.
CUCM <-----> SIPTRUNK<-----> VG <----- >PRI LINE
Solved! Go to Solution.
01-10-2021 10:19 AM - edited 01-10-2021 10:22 AM
Yes that’s absolutely possible. It’s a standard setup with ISDN on the PSTN side, aka PRI for the connection to PSTN and then SIP on the VoIP side, aka to CUCM. This would be a classic TDM type of voice gateway.
01-10-2021 04:41 PM
On CUCM, voice gateway with PRI can be configured using below
01-10-2021 08:20 AM
01-10-2021 09:54 AM - edited 01-10-2021 09:56 AM
No need to mix in H323 in the setup. You can achieve all that you ask about with only SIP. There are plenty of documentation on cisco.com on how to setup a voice gateway with a SIP trunk to CUCM. For SRST it works equally well with either protocol.
Here is one starting point for gateway configuration. https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/config_library/15-mt/vg-15-mt-library.html
01-10-2021 10:05 AM
thanks. My question is that can I use one side SIP trunk ie CUCM to VG
on the other side from VG to telcom provider just the PRI connection. I cant request client for SIP trunk at this moment. because they have existing PRI line.
CUCM to VG --> SIP TRUNK
VG to Telcom --> PRI configuration with dial peer.
This is part of migration of Nortel to CUCM ..
01-10-2021 04:41 PM
