H323 Gw DialPeer Selection Based on Calling Number
mesut ozcan
I need to choose right FXO port to send calls to same destionations.
For example while calling 0.00!, some ip phones must use 0/1/0 FXO port and some others use 0/1/1 FXO port.
Is there any way to do it?
Btw, a dial-peer like below can solve this issue?
dial-peer voice 1 pots
answer-address 492001
destination-pattern 0.00T
port 0/0/1
prefix 00
Does this dial-peer mean calls from 492001 DN, to 0.00T destination will pass through on port 0/0/1?
Mesut
9 Replies 9
Nadeem Ahmed
It's not a match all, it's a match any.
The matching order is:
1 - match answer address
2 - match destination pattern
Once you match a dial peer with one of these, it will route.
Just go through this
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml#topic3
Br, Nadeem Please rate all useful post.
Is there a solution to route calla from a particular port to a destination based on calling number ?
Hi Mesut.
You can use this solution.
configure a translation pattern to apply a prefix to called number.
voice translation-rule 10
rule 1 /.*/ /1070\0/
create a translation profile
voce translation-profile out-port0
translate called 10
than configure a voip dialpeer matching calling number ans apply the translation profile
dial-peer voice 100 voip
answer address 492001
codeg g711ulaw
dtmf-relay (whatever you need)
translation-profile incoming out-port0
And last configure a pots dialpeer matching the configured prefix and setting the exit port you want that users to use.
dial-peer voice 1070 pots
destination-pattern 1070T
port X/X/X
In this case an incoming call from a user with extension 492001 will be matched by dialpeer 100 and 1070 will be applied to dialed number.
VG , than, will select dialpeer 1070 as outgoing DP, prefix will be stripped and the call will go out through the selected port.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
Firstly thank you for your answer.
I tried to configure my router as this but calls are unable to match outbound dial-peer.
This is configuration;
voice translation-rule 11
rule 1 /.*/ /11\1/
voice translation-profile Outgoing-Ports
translate called 11
dial-peer voice 11 pots
destination-pattern 11........
port 0/0/0
dial-peer voice 1 voip
translation-profile incoming Outgoing-Ports
answer-address 499109
*Jan 25 06:42:41.810: //-1/80B1D6150300/DPM/dpAssociateIncomingPeerCore:
   Calling Number=499109, Called Number=88796388, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
*Jan 25 06:42:41.814: //-1/80B1D6150300/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=88796388
*Jan 25 06:42:41.814: //-1/80B1D6150300/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
*Jan 25 06:42:41.814: //-1/80B1D6150300/DPM/dpMatchCore:
   Dial String=88796388, Expanded String=88796388, Calling Number=
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
*Jan 25 06:42:41.814: //-1/80B1D6150300/DPM/dpMatchPeertype:exit@6076
   Match Rule=DP_MATCH_ANSWER; Calling Number=499109
   Dial String=, Expanded String=, Calling Number=499109T
*Jan 25 06:42:41.814: //-1/80B1D6150300/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1 Is Matched
   Result=Success(0) after DP_MATCH_ANSWER; Incoming Dial-peer=1
*Jan 25 06:42:41.814: //-1/80B1D6150300/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Jan 25 06:42:41.814: //-1/80B1D6150300/DPM/dpAssociateIncomingPeerSPI:exit@6655
   Result=-1
Do you have any idea
Mesut
Even translation profile works fine, outbound dialpeer is not matched.
rule 1 /.*/ /11\0/
Router#test voice translation-rule 11 87945612
Matched with rule 1
Original number: 87945612       Translated number: 1187945612
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
Mesut
Hi Mesut,
Please modify your dialpeer 11 with:
destination-pattern 11T
Please post your actual config and a debug voip dialpeer inot
Carlo
Arun Thomas
How are you going to identify the phones? do they have continuous DN numbers?
For eg;
If you want phones from DN's 492000 to 492009 then you need to configure
dial-peer voice 10 voip
answer-address 49200.
translation−profile incoming DN49
port 0/0/1
voice translation−rule 1
rule 1 /^000/ /800/
destination-pattern 800T
port 0/0/1
Prefix 00
000.! Calls from 492000 to 492009 will route via 0/0/1
Thank you for all your suggestions.
I checked debugs and saw that, incomming dial-peer is matching with belowe dial-peer.
session protocol sipv2
incoming called-number .
voice-class codec 1
dtmf-relay sip-notify
Thats why, numbering transformation is not triggered on the configured dila-peer.
Is there a way to prioritize this dial-peer agains dp1?
dial-peer voice 2 voip
Incomming dial-peer is first choise to match a dial-peer as you know.
Mesut
First of all why do you need that DP? Even if there is no dial peer for incoming it should use the default dial peer (DP0)
Would you mind posting the 'sh run' here ?
