Has anyone experienced,Music on hold getting distorted when a call through a gateway is put on hold from the CUCM?
If I simply explain the network of mine is that we have a CUCM with some IP Phones , and also the CUCM has a SIP trunk configured to a gateway which then connects to a analogue PBX via a DPNSS link. Calls can be made between the CUCM IP phones and the Analogue phones connected to the analogue pbx via the SIP trunk and all looking good. When I put the call on hold from an IP phone, the analogue phone can hear the music on hold fine up to 2 mins 40 seconds, then the music on hold starts to distort.
I am just wondering, if anyone has experienced the above and if so know what is causing the issue? Thank you
G
Hi gaya,
I never have worked with DPNSS link before but did you check if it s a network issue? What CUCM version are you running? Please give us some additional information about the gateway.
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
